Dane techniczne 1g |
Piachu_85 [Usunięty]
Wysłany: 27-10-2005, 09:10 Dane techniczne 1g
Witam Wszytkich . Chcialbym dowiedziec sie o o dane techniczne pierwszej generacji Mitsubishi Eclipse. Dzieki
[ Dodano: 28-10-2005, 10:46 ]
To jesli nie chce wam sie tego napisac to prosze przynajmniej o dane na temat przyspieszenia Eclipsa z silnikiem 2,0 16v DOHC . Z gory dzieki ! |
ChlewioR [Usunięty]
Wysłany: 04-12-2005, 22:26
MITSUBISHI ECLIPSE GT 1992
CAR SPECIFICATIONS
Engine Displacement: 1997 cc.
Engine Location: FRONT
Engine Type: NORMAL
Engine Max Horsepower: 110 kW
@: 6750 rpm
Engine Torque: 175 Nm
@: 5500 rpm
Compression Ratio: 9.8 :1
Maximum engine speed: 7000 rpm
Start Engine Speed: 3400 rpm
with Clutch: DUMP
Transmission Type: MANUAL
Number of Gears: 5
Gear Ratio 1st: 3.08 :1
Gear Ratio 2nd: 1.95 :1
Gear Ratio 3rd: 1.29 :1
Gear Ratio 4th: 0.94 :1
Gear Ratio 5th: 0.76 :1
Gear Ratio 6th: :1
Final drive ratio: 4.32 :1
Driving wheels: FRONT
Car test weight: 1215 kg.
% weight on front wheels: 59 %
Wheelbase: 246.9 cm.
Tire section width: 195 mm.
Tire circumference: 1.94 m.
Wheel diameter: 38 cm.
Tire profile: 60 %
Coefficient of drag: 0.29
Frontal area: sq.m.
Overall height: 132.1 cm.
Overall width: 168.9 cm.
Ground clearance: 12.7 cm.
STANDING START ACCELERATION RESULTS
Starting vehicle speed: 0 kmh
Starting engine speed: 3400 rpm
Starting gear: 1st
Optimum Shift Points:
1st 7000 rpm @ 61 kmh
2nd 7000 rpm @ 97 kmh
3rd 7000 rpm @ 147 kmh
4th 7000 rpm @ 203 kmh
Time to Speed:
0- 40 kmh............ 2.2 sec.
0- 60 kmh............ 3.4 sec.
0- 80 kmh............ 5.6 sec.
0-100 kmh............ 8.2 sec.
0-120 kmh............ 11.3 sec.
0-140 kmh............ 14.8 sec.
0-160 kmh............ 20.6 sec.
0-180 kmh............ 27.4 sec.
Time to Distance:
0- 100 m............ 6.8 sec.
0- 400 m............ 15.9 sec.
@ 145.1 kmh
0-1000 m.(1 km)..... 29.0 sec.
@ 183.6 kmh
Top Speed............. 221.9 kmh
by Car Test (przyspieszenia mierzone dla czasu zmiany biegu 0,35-0,40 sek) |
deenbe [Usunięty]
Wysłany: 04-12-2005, 22:54
ciekawy ten cartest:) moj colcik pokazuje tam 8,7do100 i 16.8 na 1/4 mili a jak widac eclipse 8.2 do 100 i 15.9 na 1/4 ciekawe:) czyli eclipse powinien mi zloic dupe ostro |
ChlewioR [Usunięty]
Wysłany: 06-12-2005, 09:33
| Nikt nie powiedzial ze to swieta prawda, ale tak wyszlo. Poza tym sprawa jest do ogarniecia:) trzeba sie kiedys ustawic i juz:D |
deenbe [Usunięty]
Wysłany: 06-12-2005, 12:43
[ Dodano: Wto Gru 06, 2005 4:47 pm ]
Co do ustawki to chyba nie dojdzie do niej , no chyba ze na nastepnym oficjalnym spocie mitsumaniakow, ale wtedy to autko nie powinno byc juz w specyfikacji seryjnej no i oczywiscie jak zdaze przyleciec z anglii |
Memphis [Usunięty]
Wysłany: 19-01-2006, 23:50
| A czy jest ktoś w posiadaniu takich danych dla GSXa ?? |
Hubeeert
Mitsumaniak na urlopie
Auto: TOYOTA YARIS 4EVER
Wysłany: 20-01-2006, 09:43
| www.dsm.org - znajdziesz wszystko co chcesz i nie chcesz wiedzieć o Eclipse. |
Thomas Jefferson said:
Just think...
Memphis [Usunięty]
Wysłany: 20-01-2006, 19:41
Eeee fajne
Dzięki Huberto |
arni0000 [Usunięty]
Wysłany: 16-03-2006, 12:58
| ChlewioR napisał/a: | MITSUBISHI ECLIPSE GT 1992
Time to Speed:
Time to Distance:
@ 145.1 kmh
@ 183.6 kmh
Ciekawa wersja GT słyszałem o GS, GST, GSX ale GT i to przyśpieszenie 8.2 kurcze niezła rakieta seryjnie ciezko zejśc do 9 sekund. |
ChiKenn [Usunięty]
Wysłany: 16-03-2006, 17:06
GSem spokojnie da sie zejsc ponizej 9 sek... |
Bartek
Mitsumaniak friendly admin
Auto: A161, EC5W, GF6W, A03A
Pomógł: 291 razy Dołączył: 21 Mar 2005 Posty: 6991 Skąd: że znowu? (W-wa)
Wysłany: 16-03-2006, 17:21
W Cartestowe wyliczanki mozna wierzyc +- 2 s.
Ale potwierdzam - Galant majacy 133 Km na kolach, przy przepinaniu z 1 na w 2 ok. 1 sekunde (synchronizator nie pozwalał szybciej ) napedza sie do 100 km/h w 8,9 s. G-tech pokazywal powtarzalne 8,5 s do 60 MPh. Mam troche dluzsza skrzynie niz Eclipse, bo 100 km/h mam na 2 biegu przy ok. 6500 rpm |
_________________ Pozdrawiam
MITSUMANIAK Bartek
Outlander III '14
Galant 1600 L '82
Legnum VR-4 '99
Space Star '14
